Home > Technical (L322) > Racked off!!! ;) |
Probably. Not done a FFRR personally but I have done loads of others, all teh same principle really. See if you can get a service kit from ZF.
29th May 2015 3:19pm |
Wofforduk Member Since: 08 Oct 2014 Location: Bromsgrove Posts: 9 |
Thanks mate
29th May 2015 3:23pm |
Turns out im really not sure if this is a bush.
3rd Jun 2015 11:48pm |
As far as I can tell you are referring to the inner track rod joint, as that is what is under the gaiter.
13th Jun 2015 7:48am |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 |
I would also suspect the inner track rod - the LHS one on mine went and it used to clunk noticeably
13th Jun 2015 8:08am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16175 |
Check the rack securing bolts too... Have found a couple loose now which creates the most hideous knocking noise!
13th Jun 2015 8:51am |
Given I don't have a torque wrench (must get one) I do a lot of "tightening from memory" .
13th Jun 2015 10:11am |
