Home > Technical (L322) > Checking turbo to intercooler hose... |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2926 |
Hi all
3rd Jun 2015 1:56pm |
Well the circlip turned out to be half one and rusty. I can wobble the aluminium fitting around on the inlet stub with what's left of the circlip still attached. I pulled it off and I can see how it works now. There's a seal in the tube so I'm just wondering if that's a replaceable part?
3rd Jun 2015 2:39pm |
I've just removed and checked all hoses and they seem ok. No splits or tears anywhere that I can see.
3rd Jun 2015 4:55pm |
Blimey, has everyone left or something? |
3rd Jun 2015 7:49pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
(Speaking about cars generally) most cars have an O ring seal where an ally bit of the boost system pushed onto another bit. If the clip breaks/rust so the fitting becomes loose it moves about and wears the O-ring. If you fit a new clip so it's solid it'll still leak as the seal is worn.
3rd Jun 2015 8:05pm |
