Home > Wheels & Tyres > Tyre wear |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
I'd recommend getting a proper 4 wheel computer alignment done. You can have a car that drives fine but with the caster, camber and toe geometry all over the place. It's not until it's set up properly you realise how bad it was.
29th Jun 2015 5:48pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1619 |
Cheers my friend.
29th Jun 2015 6:41pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
Just sit in it whilst he does it. middle of back seat... Pete
29th Jun 2015 6:53pm |
Best kits for the alignment is the hunter Hawkeye, make sure your chap can check the front and rear toe, camber, castor, steer ahead etc.
29th Jun 2015 8:25pm |
Cheers Gents 405 AB exec seats Baltic and Cirrus
30th Jun 2015 8:09am |
Roystonh Member Since: 21 Nov 2011 Location: Kent Posts: 395 |
Isn't Tyre Wear a place in the North East?!! 2005 L322 Vogue Gold gone
30th Jun 2015 3:00pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34925 |
if you say it with a geordie accent it is... ... - .- -.
30th Jun 2015 3:54pm |
But they're still only as good as the bloke using them. The Hoffman and is it John Bean or something? are both capable of good results if used by someone who knows what they're doing. Used by numpty none of them will be much good. |
30th Jun 2015 4:43pm |
^v true.
30th Jun 2015 4:56pm |
The Hoffman one i had mine done on has that too. |
30th Jun 2015 5:13pm |
