![]() | Home > Technical (L322) > Help car wont let me in |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8775 ![]() ![]() ![]() |
Check there is no RF interference nearby, as this can knock out the fob. Power lines radio control units, transmitters etc.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
Presuming the car could be opened with the fob before I would suggest being patient and keep trying.
Ziggy Member Since: 26 Dec 2011 Location: West midlands UK /sydney AU Posts: 265 ![]() ![]() |
If the key doesn't operate the lock it sounds like the mechanism for that part may be scoobied. Other than that you question is how can I brake into a FF, which might not be the best thing to answer on an open forum👍
Sent you a PM Ziggy, I hope it helps. MY 2010 5.0 SC Galway green and sand interior!!
Thanks EB will give that a go before the window option tomorrow |
You have another pm which indicates how to access should the above not work. |
Thanks NDFI, thats another thing to do, at least we should be able to get in....
