Home > Technical (L322) > L322 tailgate /load space lights |
Change the bulbs for leds? |
25th Jul 2015 2:46pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7914 |
They should switch off after 16mins, mine certainly do, if they don't do what NDF says, LED bulbs and you can leave them on for hours without effecting the battery... Pete
25th Jul 2015 3:53pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
^^ Days even! FYI they are NOT canbus Yesterday I couldn't spell Engineer... Today I are one!
25th Jul 2015 11:15pm |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1227 |
My wife leaves the tailgate open when doing the horses with the dogs in the back of the rr and the light stays on, can you get led's from any auto store? |
25th Jul 2015 11:25pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
Hold the interior light switch button for 10 or 15 or even 20 seconds and the interior lights will flash once then stay permanently off until you reverse this procedure to switch them back on
25th Jul 2015 11:58pm |
This is the sort of thing that you want
26th Jul 2015 1:24am |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 605 |
Found a quick and easy way is to push both latches shut manually (one on tight and one on top tailgate). Makes the car think the boot is shut. If I remember correctly might only need the top. Just push the button to unlock again. Ed |
26th Jul 2015 2:06am |
Fish Member Since: 30 Aug 2014 Location: Bolton Posts: 301 |
I changed mind to LED for the same reason. Turning off the lights only turns the cabin lights off on mine, not the tailgate lights |
26th Jul 2015 8:03am |
Thanks Craig, will try that |
26th Jul 2015 8:53am |
You can use an iiD Tool to stop the interior lights coming on if the tailgate is open , if that helps . 2008 MY Supercharged
26th Jul 2015 10:23am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34929 |
axles correct,
26th Jul 2015 10:47am |
Cool, now I just need my iid tool to arrive |
26th Jul 2015 11:34am |
Your welcome Paul |
26th Jul 2015 7:57pm |
SCPB Member Since: 16 Jun 2015 Location: Surrey Posts: 72 |
This is really helpful, I was wondering whether I could prevent the interior lights coming on with the tail gate open. I have just been outside with my IID BT and gone into the CCF files but I can't seem to find that option, come to think of it I can't find the other options Stan has highlighted, window closing, sun roof closing etc. Is it under CCF Body control? 2010 5.0 SC Autobiography |
27th Jul 2015 9:41pm |
