Home > Technical (L322) > 5x Starter Motors Burnt out. What can be the cause?
biffa
2009 Range Rover Vogue TDV8 Rimini Red
Hi. My 2009 Vogue is pretty perfect apart from one thing.
The starter motors burn out. I have now had about 5 of them fitted. Some under warranty, some not? Last time a starter motor was fitted, I asked the garage what can be done about this recurring problem. They said nothing, without great expense investigating it. The actually said I should sell the car.
Please. Someone else must have had this problem? Does anyone else have any tips/advice please.
Thank You
Mark
Post #339036 25th Jul 2015 3:11pm
Stephen.125
2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
I'm far from an expert, but could something be increasing the effort needed to turn the engine over?
I was wondering if the wrong viscosity oil perhaps too thick, may need more 'guts' to overcome it's stickyness/inertia.
Again, probably nonsense, but something is increasing the load- trying to work backwards from there!
I hope you get it sorted- would be a real shame to have to draw stumps.
Steve
Thumbs Up Formerly happymadison1978
Post #339050 25th Jul 2015 5:18pm
miggit
The commonest cause of starter motors to burn out is old age, but you've got that one covered! The second most common cause of starter motor burn out is the starter sticking on, or staying engaged after starting. This can be either a build up of dirt which stops the gear retracting when you let go of the key, or could be a short in the ignition, holding the starter motor in the start position when the key is released. Could also be a sticky starter relay, which would have the same effect.
Either way you should get to the bottom of the cause, cos sticking starter motors are a known source of ignition for car fires Shocked
Plus they ain't cheap to buy, although I imagine that you could negotiate a discount for bulk purchase Wink
If your garage is reluctant to take on the work, I would suggest a good Auto Electrician would be able to sort it out Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #339100 25th Jul 2015 11:10pm
Are they reconditioned starters? Are they definitely the correct part number for your ffrr? Previously..
Post #339102 25th Jul 2015 11:19pm
Amazing
extra load, does engine stop dead quick when off? try turn from crank,check aircon clutch
low voltage, low volts would draw extra amps, check both battery and charge circuit.(can cause premature brush/commutator failure
sticking.seems unlikely over so many, but ring gear may be issue if one has burred ring edge affecting all which follow (have a peek)
alignment.seems unlikely in situ hard to check check mating face is flat
ingress damage,dirt/water should be obvious on starter.
do you have the old starters? it is better to have and not need then need and not have
Post #339115 26th Jul 2015 7:35am
