Home > In Car Electronics (L322) > Ignition controlled live |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 |
Whilst looking through the forum to find any info on fitting a dash cam and hard wiring into an ignition live. Really couldn't find anything that definitely stated which fuse in the front was used, so I looked through the wiring diagrams and done some testing with a multimeter and found that fuse 5 is controlled by the ignition.
30th Jul 2015 9:30pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34918 |
thanks mark...i have noticed that fuse numbers and their functions differ quite a lot through the model range.. ... - .- -.
30th Jul 2015 10:55pm |
Stan,
30th Jul 2015 11:00pm |
^ Plug you piggy back connector into an un-used fuse position then you won't affect anything.
31st Jul 2015 11:47am |
I used fuse 5 in the front. Labeled for diagnostics port and transmission - no adverse affects yet.
31st Jul 2015 3:49pm |
