Home > Technical (L322) > SC 4.2 Brake adjustment |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1692 |
You can't adjust the front brakes.
1st Aug 2015 8:13am |
^ as mikey said there is no adjustment in the front discs and pads, they are self adjusting so to speak. The pads wear, get pushed closer to the disc, to compensate more fluid from the reservoir enters the system and the reservoir levels drop.
1st Aug 2015 8:44am |
georgedb Member Since: 12 Apr 2015 Location: Gauteng Posts: 82 |
Thanks northernmonkeyjones and Mikey.
1st Aug 2015 9:06am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6661 |
Have you bled your brakes at all, or checked that the calliper isn't seized? Got - 2017 SDV8 Autobiography in Loire Blue
1st Aug 2015 9:40am |
Mmmmm since I have some family living in Gauteng, I'd better see if I can help here . My kids really like their granny
1st Aug 2015 3:50pm |
@Alan: I know some work had been done on fhe brakes when I purchased the vehicle 4 months ago. Not sure if it had been bled.
1st Aug 2015 4:25pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
So to summarise it can be caused by;
1st Aug 2015 4:34pm |
Thanks Zirconblue.
1st Aug 2015 4:37pm |
nemmi69 Member Since: 16 Jun 2015 Location: Peterborough Posts: 101 |
If the brake pedal feels OK then i would check the discs first as its very hard to sop with glazed or rusted discs. If the pads are shiny then they wont stop you. What doesn't kill you is just bidding it's time. |
4th Aug 2015 2:17pm |
