Home > Maintenance & Mods (L322) > Dash facia control dials |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
I think the knobs are an integral part of the panel as they have a push button in the middle of them.
5th Aug 2015 8:56pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7631 |
I believe this has been covered a number of times on here.
5th Aug 2015 9:07pm |
hex Member Since: 22 Jun 2014 Location: coventry Posts: 108 |
Did my 2002td6 and posted the results on here .
5th Aug 2015 9:21pm |
Aren't the 2007-2009 heater panels interchangeable with the earlier ones? They look like the same panel, just with different knobs on.
5th Aug 2015 11:06pm |
J90 Member Since: 02 Jul 2013 Location: Somewhere south of Bergerac Posts: 651 |
Thanks guys. |
5th Aug 2015 11:22pm |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
yes you can use the later heater 2007-2009 control panels on earlier cars they are the same units just with slightly different buttons. i bought a 2007/8 panel from a diesel and then just swapped over the grey fascia as the earlier one is slightly lighter than the 2007+ and then reprogrammed it to my car and options, worked a treat all the connections are identical
8th Aug 2015 4:44pm |
