Home > Technical (L322) > Engine vibration |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 |
I'd second the TC suggestion.
23rd Aug 2015 9:12am |
alx Member Since: 13 Jul 2014 Location: Beds Posts: 99 |
Lost for Words, thanks for the link. Yes, the problem appears very similar to what others experience. I don't know if the fluid has been changed before so will assume that it hasn't.
23rd Aug 2015 9:34am |
I don't believe a recon TC is a good idea TBH; I would (and did) simply get a new one. By the time the tranny's out, its not worth the saving IMO (he says, having spent >4k on the D3... ).
23rd Aug 2015 10:06am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
I would suggest that you talk to Ryan at LR, he's got his own section here.
23rd Aug 2015 3:36pm |
Going to do a mega flush next Monday, then try to get the main dealer to replace the TC. Will update this thread. |
4th Sep 2015 12:24pm |
A flush can't revert the damage, so it's not a cure, but it might, particularly in combination with a dose of Dr Tranny (seriously - not a joke!), relieve the symptoms for a while. I would be concerned though, that in your situation, that is not going to help you to get anything from the dealer, so I would be pushing for a new TC before doing anything else. Visiting from DISCO3.CO.UK
4th Sep 2015 1:01pm |
I realise that the flush is not the cure but the main dealer maintains I have to do a double flush with them as a first step. I just don't want to pay £1200 for the privilege hence why I want to use an alternative at 1/4 of the price.
4th Sep 2015 1:09pm |
Ahh, right, didn't realise you meant from the dealer. I would still be arguing that they should be paying for that too though.
4th Sep 2015 1:30pm |
The car was under LR warranty when the issue was reported so even though we're out of warranty due to mileage being >100K, Stratstone are still supporting us. Well kind of as they demand £1200 for the flush first
4th Sep 2015 1:36pm |
£1200 for the flush.
4th Sep 2015 1:49pm |
The parts alone were about £600 (filter, oil?). I suspect they wouldn't even do it, just take the money then get on with TC replacement which will probably need a flush anyway? You're right though, no way I'm paying for that.
4th Sep 2015 1:58pm |
Just had a word with Automatic Choice. They only offer rebuilt units in exchange for the core. I will need to supply the gearbox part number which is cast on the box itself but it's a LOT cheaper than the quote from LR. |
4th Sep 2015 2:11pm |
The body-off method was chosen to get other stuff done too. Not sure of the differences on the L322, but on the D3, you certainly can do it body-on - but then comes the stuck bellhousing bolts and the fiddly COP brackets etc. For someone who knows what they're doing, it's under 3 hours to take the body-off a D3/RRS.
4th Sep 2015 2:14pm |
Odd, since mine certainly was a new unit. Visiting from DISCO3.CO.UK Discovery 3 TDV6 Auto HSE Zambezi Silver |
4th Sep 2015 2:17pm |
