Home > For Sale & Wanted > [Wanted] 12volt Winch....
Anyone got a 12volt winch cluttering up their garage and wants some beer tokens....???
Anything and everything considered even non working... Thumbs Up Thumbs Up
Cheers Pete
Post #344045 24th Aug 2015 1:56am
sako243
Yep
Sort of
Naturally
Oh - you wanted the winch in exchange! Whistle
Sorry have plans for it involving the RR when I get around to it... Ed
Post #344430 25th Aug 2015 10:25pm
Same here but I'm after one for the other end..... Rolling Eyes Pete
Post #344434 25th Aug 2015 10:41pm
Welshdragon
Dare you to fit a gigglepin 8274 ( twin motor)....They are stupidly quick mate, have one on the 90, brill kite it is. But the g 10 on our 110 will pull a house off its foundations Laughing
Good luck in your search Thumbs Up If it dont work.......burn it!
Post #344436 25th Aug 2015 10:52pm
Had an 8274 on my classic, before Gigglepin though... bought it for £50... Big Cry Big Cry too busy working to use it so flogged it with the truck....
Can't justify spending more than half the cost of the FF on a winch unfortunately....
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
Post #344451 26th Aug 2015 12:09am
Welshdragon
Brilliant Pete Thumbs Up Thumbs Up If it dont work.......burn it!
Post #344460 26th Aug 2015 7:15am
sako243
If you're willing to go new I had a Champion (now Warrior) 10,000lbs winch on my 110 for a while. Slow but stupidly strong and cheap (maybe £200 new I think). Was laning with the chap last Saturday and had the same comment, very slow but no hint of struggling or failing. And I abused that winch, sat out in the rain, never got washed etc and always worked.
Did once open it up, everything looked fine so put it back together with original grease etc. Ed
Post #344585 26th Aug 2015 7:55pm
Ed
That is probably the way it will go, had a couple of them before and as you say pretty slow but that doesn't make too much odds in an auto, bit of a pain having to slip the clutch in a manual to drive with it but for the fatty it should be fine, they do do a HS version which has a larger motor and different gearing and funnily enough the identical load and no load speed of the 8274... had one on my last Disco and it was very good....
I asked here and a few other places just on the off chance... you never know.... Thumbs Up Pete
Post #344603 26th Aug 2015 9:03pm
Welshdragon
David Boyer has some good winches ( no pun intended) Thumbs Up
http://www.goodwinch.com/
I have a G10 on the 110 and a earlier tds ( not sure what it called at the mo) on the 90 rear. If it dont work.......burn it!
Post #344621 26th Aug 2015 10:22pm
He does the TDS Goldfish now, saw it on his stand at Billing, submerged in a tank of water and still working...
I don't need that though...... Whistle Whistle Whistle
Thumbs Up Thumbs Up Pete
Post #344630 26th Aug 2015 11:09pm
