Home > Technical (L322) > 2004 L322 Battery Drain - searched and tried loads! |
The next easiest thing to check is for battery drain down through the alternator when the engine is off.
3rd Sep 2015 5:25pm |
Lenb Member Since: 03 Sep 2014 Location: Leicester Posts: 132 |
There was a supplementary Nokia phone cradle wired in by previous owner. I removed it (although only by cutting wires as no idea where wired in
3rd Sep 2015 5:44pm |
I asked about the telephone because on my car, which also suffered a battery drain initially, the telephone didn't work.
3rd Sep 2015 5:52pm |
Ok Thanks! Will have another look to see if I have the same Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
3rd Sep 2015 5:57pm |
sass Member Since: 23 Apr 2014 Location: Helsinki Posts: 24 |
My MY 2003 TD6 had a battery drain problem, mainly due to an ancient aftermarket Nokia HF unit which was draining up to 120ma. It was "hidden" under the footwell panels. The other (remaining) hungry unit is the immobilizer, consuming more than it should. The total drainage is now down to 60ma (compared to the previous 170-200ma) and no problems with starting the car, even in the winter time. According to the authorized dealer, the immobilizer unit could be reflashed which should take the consumption back to the normal level, but they cannot guarantee that it will work after the reflash. A new unit would cost 1200 euros. The tampered immobilizer is also the reason why my fullfat's engine can be started with the gear selector on "D" and "R" but more about that in another thread on this forum. |
3rd Sep 2015 7:20pm |
Ziggy Member Since: 26 Dec 2011 Location: West midlands UK /sydney AU Posts: 265 |
Just a thought, could you not connect an amp meter up to the battery to read the drain, then get someone to watch that as you pulled fuzes one at a time
3rd Sep 2015 11:35pm |
That is on the cards! Need to get a tester first Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
4th Sep 2015 3:03pm |
alx Member Since: 13 Jul 2014 Location: Beds Posts: 99 |
Just a thought but it could be an ancient tracker with a dead battery that sits there sucking the juice. |
4th Sep 2015 3:27pm |
How would I find that?? Were they fitted in 2004? Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
4th Sep 2015 4:07pm |
This is where it gets difficult as it can be anywhere. Recently I've found one that was continuously draining my 2003 W211 E-Class Merc. It was under the rear parcel shelf. Not easy to spot unless you remove the rear bench seats... I know it doesn't help you a lot but tracker fitters don't usually disclose the location so it's not easy to find and remove one for obvious reasons. |
4th Sep 2015 4:10pm |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 |
You can measure the voltage drop across the fuse and calculate the current from that, based on the fuse resistance. A DC current clamp can also be a great help.
Trouble with that is that pulling some fuses can wake the car up - so any fuse to be removed has to be done so and then let the car go to sleep. Tracker drain...yes, been there. Visiting from DISCO3.CO.UK Discovery 3 TDV6 Auto HSE Zambezi Silver |
4th Sep 2015 4:11pm |
Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 146 |
Reading this post reminds me that I will return from holiday (with another car) and almost sure finding a flat battery on my FF. The battery drain I still haven't been able to hunt down
6th Sep 2015 4:54pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
the tracker could be hidden anywhere, in the sides of the boot, spare wheel well, under the front seats, inside the dash somewhere.
6th Sep 2015 5:51pm |
Thnx Zirconblue. Yes I understand that they are installed in a way they're not easy to find. Do you know how they look like? Never seen such a thing bfore. Are there any signs of which I should know of when looking for the tracker? |
6th Sep 2015 7:24pm |
