Home > In Car Electronics (L322) > Audio Connectivity 2008 Range Vogue newbie advice |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7770 |
It sounds like you have the genuine RR accessory fitted.
15th Sep 2015 1:54am |
baldnSlick Member Since: 13 Sep 2015 Location: London Posts: 20 |
Alistar, great info...be nice to know what the other connections are for in the lower glove box.
15th Sep 2015 9:28am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
As Alistair explained above, but to add... The CD changer for definate and maybe the USB input too??? needs the car to go to sleep before the button (with the circle or dot) will work... So, turn off the ignition & remove the key, wait for the light on the power button to stop flashing & the car is asleep. Change to CD Changer and when you put your ignition back on “voila”
15th Sep 2015 9:38am |
Cam Tech Craig....I will try that and report back, don't mind the option of using CD's though you can make a longer playlist.
15th Sep 2015 9:56am |
switch does not revert to CD player, however though life isn't perfect it is much improved having the Aux at the back of the armrest works, now this solves one issue of passengers selecting own music, and me too from my phone, if I am right an incoming call should still pair with the head unit Bluetooth, only way is to test it.
15th Sep 2015 10:27am |
I didn't use one of these on a RR, but I have a ski boat that I fitted one to - it does require you to select AirPlay each time you get in - but I think Bluetooth only supports one connection & I was already using that for a GoPro, so I went with WiFi for music. In my old RR, I just learnt to accept the limitations of the official kit - I had a dedicated iPod in the car and it worked OK. |
15th Sep 2015 10:44am |
ordered the unit suggested but also ordered a Neet airstream Wi-Fi receiver model nas 1.1, it is similary priced delivered £25 it has airplay functionality, usb powered, and Wolfson Dac it is about 5.5cm2, plugging into the aux in the back works, sounds great.
16th Sep 2015 1:29pm |
17th Sep 2015 1:39am |
