Home > Technical (L322) > Newbie - MY06 ride height drops + auto lights always on? |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 |
Hi and welcome to the forums, if all these problems have started since you had the re-map I don't think you need a dealer I think you need to revisit the guy that did the re-map and make him fix them or make him pay a dealer to put them right. I doubt that a dealer will want to touch a remapped car to put right things that a third party has upset though. IIRC for a 2006MY you can prgramme the autolocking on or off yourself - have you looked in the owners manual? Sorry to sound a bit unsympathetic - I'm not I know how frustrating these small things can be! LR doesn't take kindly to remaps and dealers are not keen to get involved with problems resulting from them. Somebody else will come along shortly and shoot me down! 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
20th Oct 2010 8:05pm |
GolfLima Member Since: 20 Oct 2010 Location: South Bucks Posts: 18 |
Thanks for the reply Tim - the suspension issue has always been there, so I don't blame the remap for that one. I'm a bit of an anal type and have therefore read the manual from cover to cover more than once - enabling drive-away locking is defo a dealer tweak (according to the manual!).
20th Oct 2010 8:19pm |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 |
The suspension shouldn't drop, so that needs investigating. Maybe you have small air leak somewhere?
20th Oct 2010 8:52pm |
Hi Fox,
20th Oct 2010 9:12pm |
It may be worth finding a friendly local independant garage that specialise in Land Rovers and pay them a visit. You can tell them about the re-map and they will be able to plug in your car and change the default settings.
20th Oct 2010 9:23pm |
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 |
I have a 06MY car and I had the dealer do all of the Key programming with the ECU. The are all definitely dealer tweaks although i seem to recall the AutoLogic diagnostic system being able to do most things...
20th Oct 2010 10:58pm |
Thanks Steve - all good info. I don't think I'll worry about the lights (will check again today and see if it's still happenning). I'll also get the lowering checked when it goes into the stealer for the programming tweaks.
21st Oct 2010 7:23am |
