Home > Technical (L322) > Help with dashboard warning message |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7635 |
That appears to be what it looks like.
1st Oct 2015 8:34pm |
Cryptic Member Since: 01 Apr 2014 Location: Manchester Posts: 63 |
Is it not a bit strange getting this after it was parked for 9 hours? (Started up, into drive, AC on and bing)
1st Oct 2015 8:46pm |
Faulty sensor ?
1st Oct 2015 8:48pm |
I didn't notice anything driving it afterwards - and did more than usual evening run including motorway stretch - a couple of hours driving. Having said that, I did think something didn't feel quite right in the last couple of miles before parking up for the night yesterday. This morning, everything felt fine - I chalked it up to my imagination. |
1st Oct 2015 9:13pm |
Today the warning came on at starting up. For first 10 mins driving, gear shifts were clunky and then smoothed out. Haven't checked the rad yet, but suspect it might all be a simple as a fluid and filter change. |
2nd Oct 2015 6:58pm |
If transmission oil cooler is clogged up, no amount of fluid and filter changes will make any difference. On a MY02 it is probably worth removing the cooler to see what is what. IIRC a new one is not all that expensive.... .
2nd Oct 2015 10:20pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
That display looks like mine That's why I got the Bluetooth IID tool, so that I could find out what it's trying to say, are you sure that it's not say transmission gone left
3rd Oct 2015 12:32am |
Oh they are quite pricey then .
3rd Oct 2015 1:41am |
Yeah, thanks. Going to check the lot - rad, pipes, cooler & do the fluid & filter |
3rd Oct 2015 9:18am |
Unfortunately the oil cooler isn't an oil cooler it's a heat exchanger, which dumps the heat from the gearbox oil in to the water system to cool it. As far as cooling goes it works very well as it also helps to get the gearbox up to working temp quicker than the old fashioned air cooled rad.
3rd Oct 2015 11:46am |
In the end, I didn't do the fluid change and cooler \ rad checks myself - time being the issue.
22nd Oct 2015 6:44pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
Personally I wouldn't go anywhere near these cheap places, having stripped mine down to see the awful work done on the box before these people are nothing but cowboys, they know what will last just outside the warranty, that's if they'd even repair it within the warranty period, they'd just come up with some feeble excuse and not pay...
22nd Oct 2015 6:54pm |
I had a look at this, but with the new box, cooler and lines mine stays well within it's temp range even when off roading all day in low box up hills.... they did design it to tow a 3 ton trailer across the Sahara, even your blue tac box should be OK..... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Parchment over Navy Interior. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand, Jet Interior. Sold 2002 L322 Vogue 4.4 V8 Epson Green, Ivory over Aspen Interior (Fatty Offroader) Sold -Click for Project Fatty off roader- Last edited by Haylands on 22nd Oct 2015 7:03pm. Edited 1 time in total |
22nd Oct 2015 6:58pm |
Fair play, Pete. In terms of recommendations, I'm in the forums' hands... |
22nd Oct 2015 7:00pm |
