Home > Technical (L322) > ABS / Hill decent problem |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 |
Hi Guys,
3rd Oct 2015 11:30am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
I would guess that the new sensor is not quite home yet, they need to fit without any force being applied to them and sit absolutely flush with the mounting, the amount of rust I had round one of mine made it sit proud and give a similar problem..
3rd Oct 2015 11:32pm |
Thanks Haylands - It's a genuine from Dan - so I'll try to refit it and see - the teeth appear to line up , but I will check.
4th Oct 2015 9:44am |
Update:
7th Oct 2015 8:47am |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
Did you end up replacing or cleaning up the ring? If cleaned - what did you use? Thanks Howard
7th Oct 2015 10:23am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
He replaced it as its part of the CV unit as stated above sir |
7th Oct 2015 10:30am |
Doh!
7th Oct 2015 10:31am |
7th Oct 2015 10:32am |
RP, glad it's sorted.... Pete
7th Oct 2015 11:33am |
