Home > Technical (L322) > 2007 TDV8 ignition lock slow to unlock, battery 12.1 volt |
Robgosty Member Since: 20 Dec 2013 Location: Manchester Posts: 232 |
As above, when key is put in seems to activate unlock slowly, always works fine but has recently become slow, noticed more on cold mornings, checked battery with IID tool and shows 11.9 volt, put voltmeter across battery after being stood overnight and reading 12.1 volt, always starts o/k but should I be looking for new battery before winter kicks in (and battery prices rise) I have found a Varta I1 Silver Dynamic 12V 110Ah Car Battery for £95.98 next day delivery, from searching this seems a decent price, my MY2007 does not have explosive battery connection so should fit o/k, can anyone confirm this for me ? |
9th Oct 2015 8:28pm |
Hi forgot to mention, voltage with engine running is 13.7ish at 2000 rising to 14.5ish at higher revs so presuming alt is o/k |
9th Oct 2015 8:49pm |
In that case it does sound like your battery. |
9th Oct 2015 9:25pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
Sounds like Battery to me too sir |
9th Oct 2015 11:30pm |
o/k, thanks for all replies, so new battery required, can someone confirm the Varta one will fit without any dramas |
10th Oct 2015 11:55am |
Send Dan @ Duckworths a PM with your VIN and ask him for a price for a LR Battery sir... You maybe surprised how close they may be?
10th Oct 2015 12:17pm |
Hi Craig, I was thinking Varta one would be better as 110 amp, is this not right ? think L/R original is only 95 or 100, sent pm to Dan for price |
10th Oct 2015 1:18pm |
My understanding is... JLR made the car, JLR ordered the battery to be made to exacting standards. For a car we all know has critical battery needs... Why run them on anything else???
10th Oct 2015 1:30pm |
Just as a matter of interest who manufactures the JLR original battery ? i had looked at the Bosch one but searching seemed to find many reports of failure |
10th Oct 2015 2:18pm |
I think Varta at present sir... Certainly making their glass mat batteries |
10th Oct 2015 5:06pm |
Bosch and Varta batteries are both made in the same factory. As CTC says LR seem to have used Varta batteries for years in Range Rovers.
10th Oct 2015 5:39pm |
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 410 |
I replaced mine with a Varta unit, but with the same specs (Size, amps, etc.) as the original LR.
12th Oct 2015 6:10pm |
