Home > Maintenance & Mods (L322) > Fitting Supercharged exhaust backbox to earlier 4.4 V8 |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1240 |
The brackets that bolt to the chassis look different, but remember a rubber hanger goes between the exhaust and the bracket. So it may be that you can leave your existing bracket in place, and the exhaust just connects using the rubber pieces as normal.
25th Oct 2015 9:12am |
Josh Wyatt Member Since: 10 Jan 2011 Location: Oxford Posts: 76 |
Thank you Fisha. I think you're right, I'm sure there's someway of doing it.
25th Oct 2015 10:21pm |
robbo770 Member Since: 10 Jan 2010 Location: Aberdeenshire Posts: 467 |
You need to get the brakes from a part of rear outer chassis supports if you put a towbar on,
9th Nov 2015 7:09pm |
