Home > Technical (L322) > Gearbox problem help |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
Sounds like the usual Torque Converter issue! Best to seek help from a gearbox specialist sir |
27th Oct 2015 12:32am |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 911 |
In my opinion it would be unusual for the transmission to go into limp-home mode just because the torque converter lock-up clutch was worn. Solenoid issues are very common on early 6HP26s and if the previous owner had a similar issue and the transmission was replaced it’s not uncommon for the mechatronic unit (which houses the solenoids and the transmission ECU) to be transferred from the old ‘box to the new one if the garage doing the work does not have the necessary diagnostic kit, as the transmission ECU is paired with the vehicle. Hence the solenoid problem is transferred across to the 'new' transmission.
27th Oct 2015 1:30pm |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 |
Thanks for your replies. Scanning with my iid tool there are no fault codes coming up, despite the gearbox fault occurring as recently as yesterday. Are there any tests I can do? |
27th Oct 2015 4:04pm |
JPS Member Since: 10 Sep 2012 Location: South East England Posts: 565 |
The same thing was happening on mine every time I drove it after around 2 miles of driving. It turned out to be a sticking rear brake caliper causing the car to go into safe mode for some reason, had this sorted and hasn't thrown the error up since. Mine is a TD6 however. |
27th Oct 2015 5:33pm |
So I spent some time looking over the car today. There are no brakes dragging or anything like that. One of the rear tyres was a few psi underinflated, no sure that would cause the problem though and even when the tyre was inflated the gearbox still felt like it was going to enter limp mode when driving from cold - slight rev fluctuating when holding constant speed.
1st Nov 2015 7:30pm |
Did you have the engine idling when you undid the plug? If you remove the plug whilst the engine is switched off fluid will come out as it is not pumping round the gearbox |
1st Nov 2015 8:42pm |
Good shout, engine was off. I'll have to check the fluid again I think! |
1st Nov 2015 8:45pm |
You need the gearbox oil heated to the correct temperature (do a search on the forum for temp) then engine running with gearbox in park or neutral remove the plug. Oil should be right on the edge of starting to drip out to be at the correct level |
2nd Nov 2015 12:05am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1692 |
The oil should be checked between 30-35 degrees on the 6HP box |
2nd Nov 2015 8:04am |
