Home > Maintenance & Mods (L322) > Lower tailgate support bolt detached |
pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218 |
Wow have you taken/ will you be able to post a picture so that members can put it into context please?
28th Oct 2015 7:45pm |
0949 Member Since: 01 Nov 2013 Location: Notts Posts: 19 |
I'll keep you in the picture-literally... |
29th Oct 2015 10:35am |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
If Landrover can cite UK weather as a reason not to tackle corrosion nothing would surprise me Howard
29th Oct 2015 10:52am |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2024 |
members/owners should check also, that these tailgate bolts are not un-doing themselves, as I found both of mine were a couple of turns out...its the slight rotation effect of the wires being folded, (I believe) that will undo a loose/or perhaps strained bolt. -only for the owner/guest to sit on said tailgate to change his/her boots, and in an instant, -offer his/her bulk to the mud!
30th Oct 2015 1:55am |
@JBA - good tip - will check mine - nothing worse than wasting a good whisky Howard
30th Oct 2015 10:14am |
on the 06MY i drive often i have replaced both units at the rear and by god they were really rusted in place!! Glad the torx screw has gone for a better bolt design! I applied a load of grease to mine and then peeled the rubber back a little and shoved loads in there to to make sure it should push moisture away and they should last at least another 10years now FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
30th Oct 2015 10:59am |
Thanks for the comments everyone. Here's the image showing the rust which appears to have allowed the bolt to pull through. Bit underwhelming for a 2012 car dont you think? Will post warranty verdict in due course
2nd Nov 2015 12:04pm |
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 410 |
2nd Nov 2015 12:58pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34918 |
i knew that the straps rust but thats really nasty.. ... - .- -.
2nd Nov 2015 1:03pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1341 |
Disappointing indeed. The 2012 vintage does seem poor for corrosion. If it was mine, I would be asking LR/its dealer whether this falls within the 6-year perforation warranty. Only Range Rovers since 1988 |
2nd Nov 2015 1:07pm |
