Home > In Car Electronics (L322) > CD Multi changer install |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
Fitted a CD multi changer from a salvage dealer. First what a job and after following the instructions on several sites and utube I found you did not need to disengage the lock cable just un bolt it, still I managed to keep the spring in place so no drama there.
31st Oct 2015 5:04pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7914 |
If you fill in your vehicle under your profile you will get a little icon to let us know which FF you have...
31st Oct 2015 6:25pm |
Profile updated, same as yours only black and no mods, perhaps that should be as yours was. |
31st Oct 2015 6:30pm |
Pete
31st Oct 2015 9:57pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Sliver box with audio jacks will more than likely be a CD emulator ( a gizmo to fool the car into thinking it's got a CD player, but it is in fact an aux input for ipod's and the like)
1st Nov 2015 3:06pm |
miggit.... he said it was working fine... Pete
1st Nov 2015 3:14pm |
Your right
1st Nov 2015 3:31pm |
Yes it is 6 and 3 which plugged straight in. Piggy backed on that wiring is a connecter that plugs into the silver box. I've pulled that off, did not notice how many pins on that plug and the silver box is in the back of the garage right now.
1st Nov 2015 3:42pm |
You've got the earlier wiring for the CD changer, I have no idea what the extra plug socket is for as my unit is the later 10 pin plug type. The silver box is aux input that would allow you to play an ipod through the car without the need of one of those less than good FM modulators. Normally they replace the CD changer, and the wires plug straight in, but you said that it was piggy backed into the wires.......... would it have been possible to plug in the CD player and leave the sliver box still wired? If so then sounds like it's the LR unit, as that is the only one that I know of that retains the CD player........... expensive
1st Nov 2015 3:56pm |
