Home > Maintenance & Mods (L322) > anyone got a broken rear wiper motor?
lee37Vernon
Hi all, followed the wiki to repair my drippy rear washer motor. I actually revived the old seal which worked better if anyone is about to do this, it seats better.
However... Putting it all back together and I've broken of they little plastic nipple in the end if the wiper motor that locates into the nut cover to supply the jets..
Needs noting as it breaks really easily, at least mine did!
Tried dealer but you can't buy the nipple on its own even though it looks like it will just pull out.
Anyone got s broken rear Motor I could rob it from? Bow down 2003 4.4 Adriatic Blue FF
Post #355474 5th Nov 2015 4:34pm
espaceboy
http://www.fullfatrr.com/forum/topic32008.html
Post #355613 6th Nov 2015 9:09pm
lee37Vernon
Thanks for link Thumbs Up
Think I'm going to screw a small screw into the remains of the nipple to pull it out ( if it will) and glue in a length of thin plastic vacuum line. This can be ran along the wiper arm then , and terminated with some scrap yard arm mounted jets from something with them as standard. Maybe.. 2003 4.4 Adriatic Blue FF
Post #355615 6th Nov 2015 9:23pm
