Home > Technical (L322) > Engine failsafe prog |
drive2tractors Member Since: 05 Jul 2015 Location: Kent Posts: 18 |
I've had this pop up along with restricted performance since I had been messing about for a couple of hours trying to get the dvd to play. I guess the battery was getting too low with all the doors open and screens on but now I have charged it it is still showing the fault. Is there a procedure I could try to clear it before I resort to a garage?? It's a 2003 Vogue 4.4V8 petrol.
13th Nov 2015 3:44pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34929 |
make sure the battery is 100% ok then after you've re-fitted it , turn the steering wheel fully left ,then fully right.. ... - .- -.
13th Nov 2015 3:49pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7912 |
Follow the battery disconnect and reconnect proceedure in the WIKI, link is at the top of this page under fullfatrr.com...
13th Nov 2015 3:50pm |
Obviously I do this with the engine running? |
13th Nov 2015 3:56pm |
I'm taking the opportunity to change the battery as it is not really taking charge, will leaving it disconnected for a while help clear stuff? |
13th Nov 2015 3:57pm |
correct do the steering wheel thing with the engine running.. ... - .- -.
13th Nov 2015 3:59pm |
Lots of info in the WIKI
13th Nov 2015 4:10pm |
Not having much luck: Battery has made a huge difference to starting so I'm pleased I changed it but I still have the EFP message and reduced performance. I guess I need to find somewhere that can diagnose the problem or get myself an IID tool.
13th Nov 2015 7:51pm |
Plugged in my new GAP reader and shows up 0x485 throttle adaption spring test failed. Fitted another throttle body but it threw the same fault. MAF and throttle pedal seem OK, could it be the plug or harness that runs to the throttle body? How would I check those?
23rd Nov 2015 11:29pm |
Plug to throttle body has very fine contacts, check they are clean and not bent, does it run OK?? does it rev up and down, does the throttle make the engine rev??
23rd Nov 2015 11:44pm |
Plug and pins seem OK. I have sprayed them with contact cleaner also. The car just idles very badly with the fault. There is no apparent response from the throttle. At this point if I unplug the MAF sensor the car stalls but if I restart it straight away it runs fine, I assume this is some kind of limp home mode but proves surely that the pedal and throttle body physically work.
24th Nov 2015 7:49am |
Car all sorted now. Found a really good local auto-electrician who cam and had a look. He checked the connections and continuity of the engine loom, all OK. Disconnected the ECU for about 45 mins, reconnected and the car was/is ok now.
27th Nov 2015 10:18pm |
Glad it's sorted.... amased it took that long with the battery disconnect but these FF's like to prove their boss...
27th Nov 2015 10:36pm |
No problem at all. And I've barely even started on the squeaking rear end!! |
27th Nov 2015 11:42pm |
That will be upper and/or lower rear hub bushes...
27th Nov 2015 11:47pm |
