Home > Technical (L322) > Fr passenger window/mirror
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
Picked my car up from panel beaters this morning.
Have found that the fr passenger window and mirror don't work from the controls.
Any hints as to what I should be looking at or is it back to repairer for them to fix.
Beast was rear ended only.
Thanks
Post #356819 14th Nov 2015 3:56am
I have never been inside the door card but I believe you can get the connections wrong or not pushed home enough , there will be something if you search but as usual it will be a bit buried . 2008 MY Supercharged
Post #356820 14th Nov 2015 4:03am
littlecub
Put my faultmate on it yesterday and it came up with,
Passenger mirror vertical/horizontal potentionmeter defective.
Interior security, fuse or cable
Upper tailgate unlock relay short to battery.
Nothing about the passenger window from drivers side not operating.
Post #357167 15th Nov 2015 11:18pm
viper
United Kingdom 2007 Range Rover Vogue TDV8 Zermatt Silver
if they have had the door card off , most likely it will be a connector not pushed in and locked down correctly. I didn't put my connecter back in ok and the central locking and window were not working, the connecter looked ok but wasn't driven in far enough
Post #357173 15th Nov 2015 11:39pm
