Home > Technical (L322) > just a quick one. again |
23rd Nov 2015 7:52pm |
thegamekeeper Member Since: 12 Nov 2015 Location: sunderland Posts: 71 |
just measured them and they are different
23rd Nov 2015 8:24pm |
viper Member Since: 11 Apr 2015 Location: manchester Posts: 271 |
take into an Indie for a diagnostic and if the sensors are working ok it may just need a calibration like mine has just had. the differences in my heights were the same in all the levels ( access, road and off road) |
23rd Nov 2015 8:36pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34929 |
these must be measured on a completely flat surface tony....if they were then you need to get an iidtool to set it up properly. ... - .- -.
23rd Nov 2015 8:37pm |
i can do most things but when it comes to technical stuff like that im useless. ile ask about for someone who has one. would the landrover dealers take my eyes out to recalibrate it |
23rd Nov 2015 8:53pm |
Also note you may only get to within 10mm side to side as this is apparently an acceptable tolerance (well, with the IID tool)
23rd Nov 2015 9:14pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7914 |
As Joe said they are totally acceptable, tolerance is + or - 9mm, you could possibly get them slightly closer but it's really not worth paying someone to do that, you will know if a height sensor gives up, the wheel is either all the way up or all the way down, they don't get progressively worse they just stop working.... Pete
23rd Nov 2015 9:19pm |
LR would want about an hour's labour for that so probably not the end of the world, but it's only basic maths. With an IID tool you can see what the current settings are and once you've measured it you add or subtract from the values on IID and re-program the car to those values. Worth checking the height sensors too. Semi-seized, or not giving accurate readings will make weird things happen. 25 odd quid each so again, not the end of the world. When I had one go on my 07 I just replaced all 4. Placebo effect possibly but it felt a bit crisper in the corners after that. |
23rd Nov 2015 9:28pm |
my indie charged me £50 , this was an 1/2 diagnostic on his automate to confirm everything was working ok and that included my return visit to actually do the calibration which took about 40 mins ..
24th Nov 2015 12:18am |
thanks lads. little things bug the life out of me. ile get them read and take it from there. ile let yous know how i get on |
24th Nov 2015 6:03am |
just called a garage to book it in and the bloke says its normally down to a bent rod (whatever that is ). booked in for saturday. is a bent rod something it could be or am i gona have me pants pulled down |
24th Nov 2015 11:27am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7772 |
Is the garage you called a main dealer / specialist that understands the car & air suspension ? |
24th Nov 2015 12:55pm |
hes not a dealer but word ishe knows his stuff. he too has a vogue and a garage around our way takes all his landrovers to him as he works on them and has all the tools and software. i know that means nothin. another landrover specialist has just quoted me £80 plus vat to plug it in his machine to check it |
24th Nov 2015 1:00pm |
I think he's talking about the rods which fit onto the height sensors, bit difficult to bend them as they are plastic.
24th Nov 2015 1:14pm |
