Home > Maintenance & Mods (L322) > Replacing Sensors still! |
Vogue Owner Member Since: 12 Jun 2008 Location: Braintree Posts: 234 |
Still trying to find out how to get to the rear sensors - my faulty one is the same as previous posts , rear left hand side - so possible wiring chafing?
27th Oct 2010 2:50pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34913 |
just looked on RAVE and it appears that the sensors just push fit in.....other than that i dont know .. ... - .- -.
27th Oct 2010 3:11pm |
David Member Since: 15 Oct 2010 Location: Murcia Posts: 301 |
i need to know too, rear right not working on mine !!!! |
27th Oct 2010 5:13pm |
This is why no one can find anything using search. 3 topics for one question |
27th Oct 2010 5:18pm |
darrenmax Member Since: 20 Apr 2010 Location: antwerp Posts: 420 |
you have to remove the rear bumper to get them out, they clip into the bumper with 3 tabs. 2002 td6 vogue, 06 supercharged facelift
27th Oct 2010 6:39pm |
fyi,there is a thread showing how to remove the front bumper. ... - .- -.
29th Oct 2010 9:10am |
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 |
Just for some more info. If the wiring loom is damaged expect it to be on the drivers side front corner and it will need to be repaired as it is part of the main engine bay loom. Therefore lots of money... My money is on your ecu being defective but have the configuration checked to ensure the front sensors are active as they can be shut off manually. 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior |
29th Oct 2010 11:44am |
netsonic Steve Member Since: 06 Oct 2010 Location: Sussex Posts: 165 |
So it’s possible the ECU can work fine for the rear but not the front, not sure the best way to test and eliminate whether it’s the loom, sensors or ECU although there is a 2003 ECU on e-bay for £50 with 17 hours to go...........tempting. In reference to the front being shut off manually this is assume would be done through the dealer computer as an option, this I am sure was not done as this did work when I first had the RR but then one day the front just stopped although I can’t recollect exactly when.
29th Oct 2010 3:47pm |
You cant swap front/rear unfortunately. I thought of this but the plugs are moulded differently so you cant make this mistake.
29th Oct 2010 3:53pm |
thinking aloud, i wonder if it could be the switch on the dash thats the problem for you two...maybe dodgy wiring behind it? ... - .- -.
29th Oct 2010 3:57pm |
Doubt it, as the rears work? |
29th Oct 2010 3:59pm |
but doesnt the switch ,only switch off the fronts when you need to.. ... - .- -.
29th Oct 2010 4:03pm |
No, it switches both off or on. The HSE doesnt have front sensors but still has the switch etc. |
29th Oct 2010 4:12pm |
if you mean my hse then yes it does have front sensors and i can switch the fronts off and still have the backs working..[i think ] ... - .- -.
29th Oct 2010 4:16pm |
