Home > Technical (L322) > gear changing |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7912 |
If it's doing it all the time then it sounds like a faulty ECU to me, they have a cold start mode that holds the gears to warm the engine up quicker but this should stop when the engine is up to temp... so if it does it all the time there is a fault with the gearbox ECU OR the engine isn't getting to temp, stuck thermostat would be the first place to look...
10th Dec 2015 11:22am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34929 |
a remap should be able to adjust the level at which the gears change ... ... - .- -.
10th Dec 2015 11:27am |
thegamekeeper Member Since: 12 Nov 2015 Location: sunderland Posts: 71 |
hi again
10th Dec 2015 11:53am |
