Home > Maintenance & Mods (L322) > An alternative to the Merc Sprinter bottle jack? |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 |
I've read through several threads about suitable alternatives to the LR scissor jack..the MB Sprinter jack is mentioned and seems popular but...
19th Dec 2015 11:40am |
Initial thoughts are it's tall and narrow. Stability might be an issue. |
19th Dec 2015 12:11pm |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 |
I have the 10-ton version and I'm very happy with it. The 4-ton one is a little on the high side, so I'd opt for the 5-ton from those.
19th Dec 2015 12:19pm |
Food for thought regarding stability- this 10t? http://www.sgs-engineering.com/garage-equi...ottle-jack
19th Dec 2015 12:41pm |
Yes, that's the 10-ton one. It is quite a lump though so do consider its dimentions carefully (also very light to use which is sort of good but a little slower).
19th Dec 2015 12:48pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
i suppose the real issue is what do you actually need the jack for.
19th Dec 2015 2:21pm |
Lots of sound advice to consider.
19th Dec 2015 3:14pm |
Just to be 100% accurate (and a bit pedantic) here, for the sake of safety:
It would be possible for greater than 50% of the weight to be lifted on vehicles with an uneven weight distribution or on uneven ground in off-road conditions etc. Personally, I always look for a significantly "over-rated" (or otherwise tried and tested) jack. You would never think it would be the case, but where heavy vehicles are concerned, it's been known for jacks to fail under their rated weight. For example, over on Disco3 we advise people NOT to purchase the Clarke 3-ton "Quick Lift" jack, because it's known to fail under such weight, despite its 3-ton rating. I find it nearly unbelievable that jacks could be made of cheese like that, but that's how it is. I guess it's much the same as LR and the OE jack. Visiting from DISCO3.CO.UK Discovery 3 TDV6 Auto HSE Zambezi Silver |
Thanks, Lost for Words.
19th Dec 2015 3:33pm |
pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218 |
I also use the bottle jack as another safety measure when the car is in axle stands. No way I'd get under a car that was only on a jack though. I'm also wary about axle stands moving or giving up the ghost too... My paranoia keeps me safe though, touch wood |
19th Dec 2015 3:43pm |
But where do you draw the line, you could have a 1000 ton jack, when does it become over kill? the sgs ones will just be the generic Chinese made jacks you get everywhere, despite their slightly misleading "precision engineering by sgs" with union jack logos. on the webpage. It's whether you can trust the ratings written on the jacks, 2 or 3 ton should be well over the minimum. But anyone can stick a 4 ton sticker on a jack.
that's a fair point, the LR workshop manual relates to workshops (which are generally flat). But even a 3 ton jack should be capable of lifting the cars entire weight (which you're never going to do in any conditions on a single jack). But it goes back to if you can trust the rating sticker on the jack.
Axle stands are fairly easy to judge. But it doesn't take much of an incline on the ground for them to become unstable. The camber of a road for example. Last edited by Zirconblue on 19th Dec 2015 4:02pm. Edited 1 time in total |
19th Dec 2015 3:56pm |
^ You MAY be correct.
19th Dec 2015 4:01pm |
I mean don't get me wrong, not everything made in China is rubbish, in fact a lot of it is pretty good. SGS may well test their jacks and have them manufactured to their spec in china, but i don't like the slightly misleading implication they're UK made with the banner they put on every item's page.
19th Dec 2015 4:13pm |
viper Member Since: 11 Apr 2015 Location: manchester Posts: 271 |
ive got a 4 ton bottle jack from halfords that I keep in the boot purely for an emergency flat tyre situation ( I use my 4 ton trolley jack all other times ) bottle jack easily lifts the corner of the car. the base is a little small so I keep a 3/4 inch piece of ply wood in there as well to give a better footprint and stability , approx 200mm x 200mm |
19th Dec 2015 5:32pm |
