Home > Maintenance & Mods (L322) > Battery cable nearly fire |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 |
Grounded battery terminal?
21st Dec 2015 10:27pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7914 |
The explosive disconnect isn't a fuse, it will only go off when triggered by the airbags and over 30mph....
21st Dec 2015 10:49pm |
Hairball Member Since: 11 Jul 2014 Location: Leicester Posts: 67 |
Hi thanks ive looked as much as i can but everything seams ok on visual check could it of done it if the lead from battery to jump point was loose also battery is loosing 1v over night so removed now charging it out car then will check if it holds a charge off vehicle it is a proxi volt energy + pv29 110ah 700a stop laughing lol this is what previous owner got in france |
22nd Dec 2015 3:55pm |
To create enough resistance to melt the bulkhead it would be a short to earth, a loose cable wouldn't do it... worth getting checked out fully by a garage, if it does it unnoticed next time it could be the end of your FF and as that wire is not fused and live all the time it could happen when you aren't anywhere near the car..... Pete
23rd Dec 2015 1:58pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2026 |
i would hazard a guess, that your 2014 battery, fried inside, and buckled the plates. so, when you know you are safe, replace it. see if you can find a warranty for the make online etc. was the battery bolted down after repalecment, as it could have shifted around and come into contact with earth etc. or pulled at the connection post... a shorted battery could explode the actual battery. remember, they are sealed, and possibly only have a crude pressure blow-off protector. (within the battery casing,) and as Pete said, the yellow disconnect will only be actuated by the SRS ECU. other areas to be concerned about, are the red terminal tot he alternator, and also to the starter motor. |
23rd Dec 2015 2:15pm |
I seem to recall someone else on here had a loose connection on the jump post and overtime it did indeed cause the plastic bulkhead to melt and leave a sizeable hole. |
23rd Dec 2015 2:18pm |
Hi thanks all for your help ive put the battery on a optimate 4 and its fully charged and holding a charge off vehicle,but ive just bought a bosch s5 020 920a to be safe .the french battery was bolted down correctly and nothing was in contact with terminals that shouldn't be etc im so convinced the jump post was loose to cause this its made a sizeable hole in plastic bulkhead but ive re fitted it in correct place with the help of a piece of square rubber silicon hose off a turbo i had lying around as said soon as i noticed it smoking and melting bulkhead i disconected it and then reconected it properly tight and started car soon as cables had cooled down and they never got hot again i drove home and the checked everything except startermotor cables and it all seems ok if i check startermotor have i got to remove drivers side wheel and then the heat shields etc like ive seen in another post or is there an easier way thanks all any other check advice is welcome i have multimeter and tools etc and a cheap plug in obd reader |
23rd Dec 2015 2:33pm |
Hi ive tried doing a search on this but im useless on comps if you find a link or anymore info would be appreciated |
23rd Dec 2015 9:07pm |
Sorry, had a search but I just can't find it. It was definitely on here though, somewhere.
23rd Dec 2015 9:44pm |
Thanks I really do appreciate your time in replying happy christmas. |
24th Dec 2015 10:42am |
New battery fitted so far so good |
27th Dec 2015 7:15pm |
Hi all just an update you should all check the cable from positive battery to bulkhead jump post as it seams that thats all it was that nearly caused my fire the nut on the back of the jump post was loose probs since new battery fitted in france .my battery holds full charge and is charging great starts first turn thanks everyone to guiding me on what to check great site and bunch of little elves |
10th Jan 2016 11:10pm |
@ NDFI, this one?
10th Jan 2016 11:57pm |
Nice one joe wish id seen that before been searching everywhere |
11th Jan 2016 12:26am |
