Home > Technical (L322) > New knocking, clicking noise on TDV8 4.4 2012
666tur
United Kingdom 2012 Range Rover Vogue SE TDV8 Zambezi Silver
My car has started making an intermittent noise, most noticeable at slow speeds. It sounds like the clicking/knocking of a solenoid. It comes from beneath the dashboard, transmission tunnel. It's sounds quite loud and quite substantial, can be subtlety felt through body of car. Everything seems to be working OK and no warning lights. Don't suppose anyone has had anything similar ? Thanks. 2012 4.4TDV8 VSE
2004 TD6 132k miles- SOLD
1995 Land Rover Defender 110 Tithonus Ex Military
1995 Land Rover Discovery 3.9i V8 manual
Post #365516 5th Jan 2016 10:55pm
loose heat shield over the prop ?. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
workshop manual downloads are in our wiki
Post #365526 5th Jan 2016 11:07pm
666tur
Thanks. I will check that out but the noise sounds more mechanical that's something loose. If that's makes sense. 2012 4.4TDV8 VSE
Post #365546 5th Jan 2016 11:53pm
Baron
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
I've just had something similar. Turned out to be a loose backing plate for front offside disc brake. It's rotted through at the mounting bolts. 4.4 TDV8 Vogue Baltic Blue MY11
Post #367693 18th Jan 2016 12:35am
