Home > Technical (L322) > Dreaded air-bag light! |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2026 |
I have a diagnostic rsw allcomms, I fixed my airbag system with it after an indy wanted to change completely the wrong part.. long story, but im in chessington surrey.
7th Jan 2016 11:26pm |
kiranl322 Member Since: 07 Jan 2016 Location: london Posts: 18 |
Can't say the door cards had ever been removed but i was hit in the rear which required a new rear bumper (seriously how can someone not see a Range Rover?? ) but i'm sure the air bag light was on before this. How can the stealer give you wrong information to change a apart? its not like parts are cheap! might have to arrange to pop down will PM
8th Jan 2016 11:10am |
just a thought, it wont pass the MOT nowdays with the airbag light on..... |
8th Jan 2016 11:11am |
yeah i heard they were introducing that, guess i should try and solve it sooner than later, thanks for the ups all the same |
8th Jan 2016 11:46am |
aclr8r Member Since: 22 Oct 2013 Location: Norwich, Norfolk Posts: 23 |
Had something very similar. Plugged RSW in and it listed the rear passenger head airbag as at fault. Got hold of a secondhand unit then removed the door pillar rims so that i could drop the headlining to gain access. Disconnected the battery then went for a relaxing coffee. Removed the offending airbag unit, fitted the replacement. Connected everything back up, Plugged the RSW in and everything now working.
5th Feb 2016 2:53pm |
