Home > Technical (L322) > Another FBH problem |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8479 |
can you hear a ticking coming from the pump when it is trying to run? you should be able to hear it as soon as it starts to fire up, regular tick at just under 1 sec intervals.
2nd Jan 2016 5:10pm |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 |
where abouts in brum are you
3rd Jan 2016 2:14pm |
Mightymarcos Member Since: 24 May 2015 Location: Alvechurch, near Birmingham Posts: 31 |
Thanks to those that replied - much appreciated.
3rd Jan 2016 4:45pm |
Ok in case others use this thread in the future, problem was nearly solved but not quite. As I said above, a couple of test firings after it all went back together we're fine. What I didn't realise is that at the end of the second firing, it actually went off because of an overheat and was then locked out. So I actually had nothing again the next morning and even a manual start would do nothing.
8th Jan 2016 8:54am |
