Home > Technical (L322) > Cheap eBay Key Fobs |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
Will the blade swap? If so thats the quick easy answer... If not, for only a couple of quid, i would order another and take it to another shop to have it cut... We have had them cut at a local Timpson’s shop... |
18th Jan 2016 9:33am |
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 423 |
Thanks Craig.
18th Jan 2016 10:02am |
Pvw10 Member Since: 04 Nov 2015 Location: Ledbury Posts: 314 |
I bought a branded copy case like yourself after checking the blade swap was possible as some are not. I then just took the thing apart(not easy) and swapped the lot, on both my keys.
18th Jan 2016 6:29pm |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
I did the same as you, new key was a bit "grabby" when it went in but it did turn
19th Jan 2016 11:25am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3195 |
@V8Noise
19th Jan 2016 11:37am |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2026 |
try lube-ing it with some pencil lead. (graphite) rub one on some medium sandpaper, and tip onto a bit of folded paper, sprinkle onto the key, but first, rub the key with a bit of spit, to get it to stick. get it into the key grooves |
19th Jan 2016 11:41am |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 |
I enquired at Timpsons a little while ago and they said the same as they've had trouble with them snapping in the ignition barrel. Visiting from DISCO3.CO.UK Discovery 3 TDV6 Auto HSE Zambezi Silver |
19th Jan 2016 11:57am |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 |
I used keys by post who cut a new blade from a photo of my original after two different cutters (one of which that was recommended) failed to cut my flip keys and the cut was great. Have used them on my BMW as well sending them the blank and again key worked no problem. I have kept one original key so I dont have to give the flip key to the garage, valet parking etc and used a set of replacement buttons from ebay and has lasted over a year . There is a difference between knowing your sh!t and knowing you're sh!t
19th Jan 2016 3:47pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 2984 |
I sent my key blank that I bought from Daveo to Express Auto Keys in Orpington.
19th Jan 2016 4:53pm |
