Home > Technical (L322) > gearbox overheating - amber message
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
Had a long journey at the weekend - half mile before home the message "gearbox overheating" came on the dashboard.
since I was only half mile, I carried on. when I got out of the car there was a very acrid smell - no signs of oil leaking our nor anything melting.
Anyways - quick research suggests that the lower part of the cooler which is used to cool transmission oil often becomes blocked and needs replacing along with new transmission oil/filter.
Clearly as the car has cooled overnight the message has now gone away.
Now I already have car booked in this week for another issue. Question is - Do I risk driving it to the dealership (about 12 miles) or do I get LR assist to come and tow it there? (don't worry I'm not gonna hold anyone accountable!! Smile Smile Smile )
Thanks
Neil
Post #367738 18th Jan 2016 12:23pm
it seems the problem comes up after a long journey, a short trip to the dealer should be ok if you take it easy.. ... - .- -.
Post #367744 18th Jan 2016 12:49pm
Ian c2
United States 2007 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
The problem is , your oil has allready overheated and will have lost some of its properties .
It may not harm the box , it may harm the box .
If you can get them to collect for free , that would be a no brainier for me .
Post #367766 18th Jan 2016 2:57pm
Fleagle_UK
Well decided to get LR assist out.
He said that my car was showing fault code P2787-4B is recorded.
Something to do with clutch temperature exceeding limit. Wow - I didn't know automatic boxes had a clutch - I though it was a viscous coupling ? Question Question
He has recommended the gear oil be drained and the system flushed.
Post #367913 19th Jan 2016 10:38am
Fleagle_UK
Censored Censored Censored Censored Censored Censored Censored Evil or Very Mad Evil or Very Mad
Sorry.
Well, LR have now had a look and as per usual tell me work needs doing but the LR extended warranty doesn't cover it.
Consequently they want over £800 to flush/replace the transmission oil and replace the filter!!!!! they haven't said what caused the overheating just that the oil and filter will now need replacement.
£800!!!!!
Now my car is 4 year old and according to the service schedule the gear oil/filter are only replaced every 9 years.
The basis of their refusal to pay is "it's a service item". My defence I guess will be .... "That's suppose to last 9 years (give or take)....not just 4 years!!!
Every piggin time I've tried to claim on the LR warranty they have argued not to pay! Worthless.
Don't even get me started on intermittent faults and their disinclination to find them. Evil or Very Mad
Post #368384 22nd Jan 2016 10:16am
Birdbrain
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi.
I'm in Cheshire and used a company in Hawarden who did a full flush and filter change on my L322 - Chester Automatic Transmission Co,. Can''t remember how much it was but certainly cheaper than a main dealer.
Post #368388 22nd Jan 2016 11:00am
Ian c2
£800 is right around where I was quoted from a dealer .
I think in the end I got a kit from Atlantic British that included the sump/filter and 6 liters of zf , at around $300
And the local transmission shop installed for $200 .
I then used some ebay bucks to buy another 9 or 10 liters of zf for about $200 and the tranny shop charged about $50 each time I had it drained and filled .
A full flush using zf is around $800 at the dealer , and the same with royal purple around $200 at the Indy .
Post #368405 22nd Jan 2016 1:25pm
^the ZF fluid is specific to the gearbox and is expensive. Royal Purple ATF isn't the correct spec for the 8 sp ZF box, or the 6 Sp box either as far as i can tell, these need to have Lifeguard 6 or 8 respectively and i don't think that it comes up to the correct spec for the box.
There are some alternatives but not many. There is nothing that can't be fixed with a hammer😜😜
Post #368413 22nd Jan 2016 2:42pm
RRPhil
I think that’s the first time I’ve seen a problem posted regarding the 8HP70 transmission. How do they reckon that replacing the filter and fluid is going to cure a clutch overheating problem? (Your transmission has 5 clutches, by the way – not including the torque converter lock-up clutch). Surely the extended warranty covers an internal fault with the transmission?
Phil
Post #368415 22nd Jan 2016 2:53pm
RRPhil
The only ‘official’ alternative to Lifeguardfluid 8 is Petronas Tutela Transmission AS8
Phil
Post #368416 22nd Jan 2016 3:04pm
Fleagle_UK
Thanks for the useful info chaps. Thumbs Up
I have asked the direct question "What has caused the overheat?" -
The technician has told to the service desk person that "it will be the clogged filter" - hence lubrication is not circulating properly hence the over heating of the "clutch".
To me - all LR have done is propose a cure for the symptoms and not the disease. i.e. - sure the filter "may" be clogged but why? - At only 4 years into a 9 year service item I can't accept that it is just "normal" wear and tear hence not covered on warranty. - which is what they are claiming.
The dealership have said they will go back to LR warranty dept and see if they are prepared to make a contribution towards it - but I am still miffed. In my mind I should be paying nothing to this problem and I still want to know what caused the problem. Sad
(also anyone know how many litres of this ZF lifeguard 8 would be needed to flush and refill my box? - thanks)
Post #368418 22nd Jan 2016 3:21pm
Ian c2
Well , I would want to look at the filter once it's changed and analyze the oil when that's flushed .
Of course I could be cynical and say actually fixing the problem would be on their dime ....
Post #368419 22nd Jan 2016 3:25pm
RRPhil
The only way the filter could become clogged is if something in the transmission was generating debris – in which case there’s an internal fault with the transmission. Land Rover technicians don’t have a clue about the operation of the transmission as they’re only trained to replace them and not fix them. You might be better off speaking directly to ZF at Nottingham – I’m sure they would be mortified to hear that one of their flagship transmissions has failed after only 4 years.
Transmission fluid capacity is 8.5 litres so a drain and refill will need less than this (sorry I don’t know the actual amount).
Phil
Post #368427 22nd Jan 2016 4:25pm
I agree with Phil, there has to be something which has caused the overheat, not just a clogged filter, something has to have worn in the box to cause the debris to clog the filter in the first place
Out of interest how many miles has it done?
ZF may be able to help but they may be more interested in what has gone wrong. There is nothing that can't be fixed with a hammer😜😜
Post #368428 22nd Jan 2016 5:02pm
Fleagle_UK
car has only done 43K miles
Post #368430 22nd Jan 2016 5:05pm
