Home > Technical (L322) > Weird Air Susp DSC ABS+warning |
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 |
Bought a 2002 4.4 2012 painted white conversion for SWMBO checked everything,rear air shocks replaced I think fronts as well, went up and down far quicker than mine, checked everything except hi/lo range as switch was busted. Drove 160 miles home no problems, next day engine management light comes on reads as implausable signal, guy says does it every now and again as LPG runs richer !!!! Will get that checked. Anyway next day normal air fault comes up, turn car off and went away, slowly got more regular and now constant but steering not too heavy, any clues, doesnt clear with solas and shows no codes, car sits at normal height. One day your life will flash before your eyes......................................make sure yours is worth watching!
22nd Jan 2016 3:56pm |
ABS unit was going to check. i even have a spare repair loom, can you elaborate on 2nd comment, was going to swap battreies with mine as I know low voltage can play havoc. One day your life will flash before your eyes......................................make sure yours is worth watching!
22nd Jan 2016 6:42pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3062 |
If Pos or Neg Lead not tightened properly onto the 2 poles (nipples! ) then they can move and lose contact which can lead to a complete power loss or interruption which can then set off/interrupt the CANBUS leading to faults showing.
22nd Jan 2016 7:13pm |
Gotcha will give nipples a firm squeeze One day your life will flash before your eyes......................................make sure yours is worth watching!
24th Jan 2016 5:04am |
mark g Member Since: 28 Dec 2015 Location: Shropshire Posts: 31 |
mine did that , it was steering wheel not centred properly, tracking adjustment sorted it |
24th Jan 2016 2:42pm |
Checked all fuses, cleaned abs connector, ran car with charger connected at 14.2 volts still no joy.
4th Feb 2016 10:11pm |
voltage at Bat was only 13.3 but the charger upped it to 14.2 One day your life will flash before your eyes......................................make sure yours is worth watching!
4th Feb 2016 10:12pm |
