Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2790 |
Best to replace the oil cooler as it can warp and leak again. 2012 TDV8 Vogue (L322) |
19th Oct 2022 11:33am |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 725 |
Not wishing to go against the grain of popular opinion...... but...... I only changed my gaskets and O-rings on New Years day! Had the cooler off, cleaned and visually inspected. I didn't change the oil cooler, as I felt that the stories about warped coolers might just be a bit of a sales technique - most garages (including independents) like to go the easy route and take your money for unbolting/replacing parts. Nearly a year down the line and approaching 10kmiles later - everything is still 'hunky dory'! In short, the whole sorting the cooler leak 'thing' cost me £50!! The older I get, the more I realise that people confuse wrinkles for wisdom |
19th Oct 2022 5:37pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2326 |
66,000 kms since I changed just the gaskets. I wouldn't be surprised if they leak again as they were the original part number gaskets rather than the new part numbers which hopefully are made of more heat-resistant material. My EGR is currently still functional so heat from the EGR cooler is still heating the oil cooler. |
19th Oct 2022 8:48pm |
blackpool Member Since: 14 Aug 2022 Location: Blackpool Posts: 24 |
Hello @JMC
14th Nov 2022 11:36pm |
Thanks for the heads-up 'blackpool'....
15th Nov 2022 8:08am |
Westridge177 Member Since: 12 Oct 2021 Location: Birmingham Posts: 17 |
Well done on the tip of leaving the first seal in place and changing the inner one first, I’m a boiler engineer and was getting ready to drop that one instead of wrapping tape around an oily component. |
2nd Feb 2023 11:09pm |
Smoggie35 Member Since: 21 Nov 2022 Location: North Yorkshire Posts: 9 |
Guys,
15th Feb 2023 5:29pm |
Jimmies Member Since: 19 Jan 2022 Location: N.Yorks Posts: 24 |
Just did this myself.
18th Feb 2023 3:16pm |
@Jimmies.
18th Feb 2023 7:46pm |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 294 |
Hi guys I have had all the same issues here symptoms burning oil smell smoke from back of engine only when car is warmed up horrible fumes in cabin so had oil cooler replaced 3 weeks ago but still the same fumes and smoke so now thinking its the pipe that feeds into the back of oil cooler the o rings as Craig said at start of this thread. Is this the same setup then for the L405 as the L322 this pipe that feeds the back of oil cooler causing the issue.
4th Mar 2023 12:23pm |
Yes. |
5th Mar 2023 2:56am |
RBFFRR Member Since: 19 Feb 2022 Location: Blackburn Posts: 4 |
Can anyone tell me what size bolt is used for the feed pipe at the rear? Mine has snapped!! Getting a new cooler, does it come with the bolts for the pipe? TIA |
5th Mar 2023 7:21pm |
The bolt is M6 x 12mm according to Microcat 2012. The same size bolt is used to hold brackets on the branch of the pipe that heads towards the secondary turbo. |
5th Mar 2023 8:52pm |
Thanks Graham. I thought it might have been an M5 as the head is 8mm and the shaft is 5.5mm wide. |
5th Mar 2023 9:06pm |
