Home > Technical (L322) > Heater blower speed indication - 2011
nbunney
Can someone with with the last of the L322 tell me if , when the fan is operational, if the leds light up to show the speed, when in full auto mode?
Mine only light up when fan speed is set manually and I'm sure they used to light up, regardless, on my old 3.6.
Cheers.
Post #370631 5th Feb 2016 7:53am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Hi, I haven't got a late l322. If they are basically the same, when I set mine to say 2, oclock manually, it doesn't speed right up until I slow down, and when over 40 to 50 mph it slows down again.
I have no idea if yours is based on the same principal.
I wish I had a 2011 ff. Big Cry
Post #370634 5th Feb 2016 8:14am
GraemeS
My MY12 does not indicate fan speed when on auto, only when manually set.
Post #370649 5th Feb 2016 10:01am
RP123
Scotland 2006 Range Rover HSE Td6 Bonatti Grey
Hi,
I have an 06. The outer dots do light up dependent upon fan speed. (unless I have it on manual fan) To have both, direction and fan on auto, remember to have both lights in the center of the button (the dot and dash) on.
Cheers
Simon
ps the fan does take a couple of mins to come up to speed when it's cold outside - stops having blowing cold air into the cabin
Post #370689 5th Feb 2016 12:03pm
Late MY’s only light up the Auto 2 buttons in the middle unless set manually sir Thumbs Up
Post #370699 5th Feb 2016 12:51pm
CS
And when using 'defrost'? Only Range Rovers since 1988
Post #370766 5th Feb 2016 7:39pm
nbunney
Thanks gents Thumbs Up
I thought it might be the case.
Another way of saving power eh Rolling Eyes
Post #370773 5th Feb 2016 8:00pm
