Home > Technical (L322) > TD6 EGR Bypass Query. |
See what happens when your EGR thermostat is always open
6th Feb 2016 11:04pm |
I've not considered taking the cooler out but have considered disconnecting the inlet pipe and fitting a bung inside it and then reconnecting it. Certainly one way not to have to worry about whether the EGR thermostat is working or not. |
6th Feb 2016 11:17pm |
NDF that's something I've thought about as well...
7th Feb 2016 10:00am |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 775 |
It is absolutely do-able. I cant remember the name of the poster but if you do a search in the AULRO.com l322 section there is a full how to with pictures to remove the whole kit and caboodle using a couple of hose blanking pieces. If I was ever to take the rad and fan out I would do the same. 2007 TDV8 VSE
7th Feb 2016 11:02am |
I found the page for you...http://www.aulro.com/afvb/l322-range-rover...tem-2.html 2007 TDV8 VSE
7th Feb 2016 11:10am |
Grr you have to join to see the pictures
7th Feb 2016 11:29am |
You can join for free but after a while you have to subscribe. 2007 TDV8 VSE
7th Feb 2016 11:47am |
I have done, also asked Harley if he would be ok with it being made into a PDF attributing the work to him and aulro and hosted in the wiki here 👍 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
7th Feb 2016 12:30pm |
sarn Member Since: 05 Apr 2013 Location: Oswestry,Shropshire Posts: 27 |
Thanks Wayneg and all others who contributed to this query. Will be changing a duff? main thermostat in the next weeks so will remove all EGR gubins at the same time. As I have machining facilities will make up the various plugs and exhaust blanking plate required. |
7th Feb 2016 3:51pm |
Currently trying to find a uk or ru source for th blanking plug kits due to the barbed end required at one point maybe two... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
7th Feb 2016 5:02pm |
Steveo Member Since: 26 Jan 2015 Location: Essex Posts: 156 |
Sorry for the hijack but are you running your td6 with just the fan disconnected or do you have kenlow fitted is there any benefit from having the fan disconnected. |
7th Feb 2016 5:07pm |
No viscous coupling or fan.
7th Feb 2016 5:37pm |
Is it easy to remove the fan ect |
7th Feb 2016 5:51pm |
Ideally you need two viscous fan removal spanners, they are quite long and thin but you need to grip both nuts, one in the pump and the other on the viscous unit and if it's the original unit they are going to be well stuck together 😥 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
7th Feb 2016 6:46pm |
