Home > Technical (L322) > Adaptive headlights. Moving not sure. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
I have the same model as yours and my adaptive lights are ace! A quick thing for you to check would be to make sure the leavers are not set to european use? If they are, that will give you a flat line beam and obviously you will see less movement without the triangle type beam pattern set for use on UK roads... |
8th Feb 2016 1:53am |
Cavalier Member Since: 04 Sep 2015 Location: Bletchley Posts: 189 |
Thanks for the reply Craig, could to tell me where the levers are. |
8th Feb 2016 11:05am |
Search button in the middle of the top bar of page sir
8th Feb 2016 11:29am |
8th Feb 2016 11:30am |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 |
I had a 2011 with adaptive lights. Driving in a straight line on a pitch black night, one could wiggle the wheel a little and see them turn with the wheel. |
8th Feb 2016 11:45am |
ha ha thought about the search as soon as I replied to your post, sure enough found the answer |
8th Feb 2016 12:06pm |
