Home > Technical (L322) > Can't jump start |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
Hi All
14th Feb 2016 9:17pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34929 |
was the donor car running? if not then thats the problem.. ... - .- -.
14th Feb 2016 9:22pm |
Yep, donor car was running and held at 2000rpm for 10 minutes 56 TDV8 Vogue SE
14th Feb 2016 9:24pm |
Jump leads went on to the jump start posts, and were checked with a multi meter for resistance to battery (in case there was a bad connection).
14th Feb 2016 9:35pm |
I'd be inclined initially to unscrew the -ve Jump post and clean up the thread and cable end clamp to bright shiny metal and refit.
14th Feb 2016 9:46pm |
Good point resistance can rise with current
14th Feb 2016 10:06pm |
I "always" (snigger) use the nut on the suspension turret for the -ve connection, but agree this would be no good if the -ve terminal on the battery itself is not connecting properly. .
14th Feb 2016 11:12pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7769 |
I have short cables with Anderson connectors fitted to all our cars & the same with the jump leads - it means I'm guaranteed a good connection on my end
15th Feb 2016 8:00am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1342 |
I recall that when my 2004 4.4 had a flat battery there was a problem with jump starting (Discovery recovery vehicle). We called LRA and got advice. I think the battery needed to be shorted out to clear the system. The car seemed to have immobilised itself, perhaps as an anti-theft measure in response to the apparent 'removal' of the battery. Perhaps someone with better technical knowledge than me can confirm? Only Range Rovers since 1988 |
15th Feb 2016 2:53pm |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 |
15th Feb 2016 4:16pm |
I was inside the car standing by to try to start it - the recovery operator had that part of the conversation with LRA and did what they said to reset the system - hence my suggestion that someone who knows what needed to be done might clarify. Only Range Rovers since 1988 |
15th Feb 2016 7:32pm |
