Home > Maintenance & Mods (L322) > TD6 Viscous Fan Delete. |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 775 |
I have read various threads regarding removing the main viscous cooling fan from the front of the engine. With the Electric fan already there controlled by the ECU it sounds like a good idea. I do question if removing the fan would be such a good idea in a hot climate so can I ask has anyone removed their fan and subsequently ran their car in very hot conditions, High 30c`s to 40c`s? Any dramas? 2007 TDV8 VSE
16th Feb 2016 3:31am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
I don't think that I would recommend removing the fan and not replacing it with something a bit more suitable....
16th Feb 2016 5:53am |
I think I have got the wrong end of the stick, I though the existing electric fan was enough on the TD6 in colder climates and the addition of Jag fans needed on the V8 only. 2007 TDV8 VSE
16th Feb 2016 7:08am |
No your right, there are some peep's who are running TD6's without the viscous fan........ but they aren't doing heavy towing or living in a country where snow is something that's only seen in pictures While I imagine that it would cope during colder months down under, I wouldn't rate your chances during the summer Yesterday I couldn't spell Engineer... Today I are one!
16th Feb 2016 8:05am |
Well thats sort of why I asked the question. I had a quick squint through rave and it appears the electric fan on the TD6 comes on gradually in steps, voltage controlled, Temp sender in head
16th Feb 2016 8:38am |
That's why I added one of these
16th Feb 2016 9:51am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
As miggit says, I'd fit a temp gauge and also fit a lower temp thermostat, I think the TD6 uses a standard size one so you should be able to put a lower temp one in cheap enough. Pete
16th Feb 2016 10:24am |
Thanks for the info. I will leave well alone. 2007 TDV8 VSE
18th Feb 2016 1:33pm |
