Home > Technical (L322) > TD6 over cooling mystery! |
sarn Member Since: 05 Apr 2013 Location: Oswestry,Shropshire Posts: 27 |
Yes miggit down to two ' bleeders ' now |
18th Feb 2016 5:37pm |
You have to remember that Diesel engines can over cool even with all the thermostats operating correctly and fully closed. Unless working hard the engine simply doesn't produce enough heat to offset the cooling effect produced by air flowing over the cylinder block. Going down hill in cold air is the very situation that overcools the engine, due it hardly producing any heat, whereas going uphill in the same air temperature will likely result in the engine temperature returning to normal.
16th Nov 2016 5:11pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
I believe that kingpleb runs a viscous fanless ffrr Yesterday I couldn't spell Engineer... Today I are one!
16th Nov 2016 5:20pm |
mariner30 Member Since: 12 May 2016 Location: SW Scotland Posts: 17 |
I really enjoyed reading all this until I hit the same problem. I was losing coolant from the EGR cooling system (I could see the drips BELOW the system pipework) and also was getting the infamous white steam from the exhaust. I removed the EGR valve but the steam continued (albeit for less time) and I was still losing coolant. So I removed the EGR cooler, blanked the pipe ends and the exhaust EGR outlet. Got rid of the steam (white smoke) but the temperature gauge now never reaches normality. Like most other posts it drops back on downhill runs and nearly reaches the 12 o'clock position on a steep hill. The thermostat was changed with the water pump about two months ago using a Eurocarparts kit. I have 2 options. Try bleeding the system again or change the thermostat for a genuine LR part. I have heard that the LR part is optimised for the Range Rover fit to avoid the engine running too cool. I could do with sorting this as I would like to see an improvement in my fuel consumption (it improved a bit after the EGR system was removed but it would be better if it ran at the correct temperature) Is there a neat way of bleeding the system (eg. car facing downhill at normal operating temperature like a BMW E36!?)
16th Nov 2016 10:52pm |
Right I may be able to shed some light on this...
17th Nov 2016 12:11am |
should be possible to adapt something like this to sort it out...
17th Nov 2016 12:32am |
Reckon that this would be better
17th Nov 2016 12:41am |
Thanks for the reply Miggit.
17th Nov 2016 11:47am |
Yes there is a way to bleed the cooling system.. but .. you have done away with one of the bleed points..D'OH!
17th Nov 2016 2:23pm |
Having done exactly the same mod as mariner30 about 6 months ago I have had the same temp. fluctuation problem. Temp. gauge slow to reach normal pottering round locally once wound up on motorway gauge drops to 1/4 or below leading to no heating. Am planning to change main thermostat for genuine LR part and try again. Find it hard to believe it could be air lock problem but you never know! |
17th Nov 2016 6:08pm |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 |
Yes diesels can cool but we also have an 03 td6 it is way difeerent.
17th Nov 2016 6:34pm |
Does anyone know for a fact that the genuine LR TD6 thermostat is optimised for this vehicle to prevent over cooling??!! If this is so then maybe their high purchase price starts to look more acceptable?! |
17th Nov 2016 6:36pm |
Zulu 10 Member Since: 28 Nov 2014 Location: Hampshire Posts: 88 |
My Td6 was/is bog standard.
17th Nov 2016 9:28pm |
Does lower operating temperature have any advantage?? |
18th Nov 2016 7:13am |
