Home > Technical (L322) > TD6 over cooling mystery! |
sarn Member Since: 05 Apr 2013 Location: Oswestry,Shropshire Posts: 27 |
Am definitely going to try running TD6 minus viscous fan just in case this is at fault. Have been meaning to do this for ages but only now the cold weather has arrived,it's become urgent! |
18th Nov 2016 4:20pm |
Bluegreygreen Rangie Member Since: 10 Aug 2012 Location: Australia Posts: 53 |
You can hear the fan if you know what your listening for when it is running / driving, they are very noisy!
18th Nov 2016 4:25pm |
mariner30 Member Since: 12 May 2016 Location: SW Scotland Posts: 17 |
Thanks for the reply miggit. However there is a bleed screw that's higher in the system than the EGR cooler supply and return (see photo)[img]
18th Nov 2016 6:31pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
My only thoughts are they've fitted the bleed screws at known airlock points in the system.. and you have done away with one.. it could just be there because the EGR cooler gets airlocked, but it could be more than that... the main bit of good news is that it isn't overheating, so it is useable But with the awy the weather has just gone you might need to wrap up a bit warmer Yesterday I couldn't spell Engineer... Today I are one!
18th Nov 2016 6:45pm |
Two week gap and about a thousand miles. I have no loss of fluid (good) but the temperature gauge is cold going downhill and warms up towards but never reaches the 12 position under uphill load. I think it might be time to change the main thermostat and I think the Gates one looks like the best option. I'll update here when I get it done. |
1st Dec 2016 7:40pm |
Ollie7195 Member Since: 11 Dec 2016 Location: Somerset Posts: 74 |
Hi guys, my TD6 is also running cold! sits constantly at 10 o'clock with very small fluctuations up or down, it did once cool down to the top of the blue section too! on a steep hill. I read that the EGR thermostat could be a problem so I made a small clamp and blocked the hose with it and its made no difference at all, I assume this would point to it being the main thermostat? as I haven't heard much about the g/b oil cooler thermostat causing a problem?
17th Jan 2017 6:54pm |
Hi Ollie7195. I removed the complete EGR system about a month or so ago. The original advice was on the Aussie RR site at http://www.aulro.com/afvb/l322-range-rover...tem-2.html
17th Jan 2017 11:01pm |
Hi mariner30! I've got the blanking kit with the exhaust manifold blank as I was planning on removing the egr completely at some point but didn't know what size the pipe diameter was for a plug (guessing around 15mm inside diameter?) and didn't want to drain it down as I need the car during the week, but thanks for the tip I had thought the vacuum pump might need to be removed as I couldn't see how to remove the turbo inlet pipe so thanks for confirming that!
18th Jan 2017 12:16am |
The LR Thermostat is LPEL000050 and retails from LR at £69.06 inc VAT. The blanking caps are 16mm and come as a pair. The water pump should be changed while you're there unless it has already been changed. The new one will have a metal (not plastic) impeller)
18th Jan 2017 10:56am |
Thanks for all that, greatly appreciated! I have no excuse not to carry on with it now I have a feeling my viscous fan may have started to cease, I had the bonnet open while idling and it was spinning round rather quickly, will have to try the newspaper test on it when its cool and see if it stops, could be that cooling it a bit too much but i doubt that would be enough on its own, I expect my valve and manifold to be pretty bad, doesn't look like any of it has been touched from new! hoping getting rid of the egr and a good oil change will make it run a lot smother, damn thing has the BMW vanos tick or something along those lines (sticky hydraulic follower) hoping its not a blocked oil way! |
18th Jan 2017 6:37pm |
Just tested the viscous fan and it appears to be sticking, I don't want to use the word cease as it can be spun by hand when the engine is off but it stops after about half a turn, but tested with the news paper and the fan showed no signs of stopping so that will be coming off and going in the bin! |
18th Jan 2017 8:40pm |
^^^^ and leave it off .
18th Jan 2017 9:06pm |
Probably right Joe 90. Just travelled about 160 miles on Motorway and country roads. Temp remained steady at 12 o'clock all the way. Time to remove the fan when I get home next week, methinks.
18th Jan 2017 10:07pm |
Finally got round to removing it all! changed the main thermostat, annoyingly the original was still holding fine when i tested it, but the water pump was the original and it was just beginning to get a bit of slack in the shaft, blanked the EGR at the exhaust manifold and boy what a difference!
27th May 2017 6:42pm |
