Home > Technical (L322) > Help |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1342 |
When my 2004 car had a flat battery it would not start on jumpleads, we called LR Assistance who told the recovery technician what needed to be done. I wasn't on that part of the call, but I think when the battery gets to a certain (low) level the system immobilises itself, 'thinking' the battery has been disconnected as part of an attempted theft. The solution seemed to involve shorting out the system to re-set it, but I couldn't say exactly what was done. Try calling LRA 0800 521 786, they advised in my case even though I hadn't had LRA since the warranty expired over 4 years before, if no-one else can tell you what to do. Only Range Rovers since 1988 |
19th Feb 2016 7:50pm |
ARH Vehicle Logistics Member Since: 28 Jan 2012 Location: Shropshire Posts: 61 |
cheers i will try If i could would you!!!! |
19th Feb 2016 7:52pm |
Sounds like a battery reset.
19th Feb 2016 8:15pm |
Battery reset will i find in the search If i could would you!!!! |
19th Feb 2016 8:20pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7912 |
Here you go...
19th Feb 2016 8:54pm |
cheers! If i could would you!!!! |
19th Feb 2016 8:58pm |
Thanks for the info on battery reset but not worked, when I turn the ignition on I don't have eml? The car just cranks over and doesn't start.
20th Feb 2016 12:03pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34929 |
read the advice in the second post.. ... - .- -.
20th Feb 2016 12:20pm |
Did you try the touching battery terminal connectors together (pos lead and neg lead when off the battery) trick to reset the ECUs ? Sounds like the same as "shorting the system"? .
20th Feb 2016 12:36pm |
Yes I read the advise, and yes I touched the two leads together and the car is still the same. If i could would you!!!! |
20th Feb 2016 12:47pm |
An update on this! I left the battery disconnected over night and followed connection procedure and it started but the same has happened today it won't start just keeps turning over!! All the faults coming up ie: suspension inactive hdc dsc all staying on or flashing up in lcd. Just put a fresh battery on and still won't start. Disconnected again and will see what happens in the morning when I reconnect!!! If anyone has had the same issue please let me know.
23rd Feb 2016 7:25pm |
Sounds like a possibly bad connection to the engine ecu or the battery is just dropping enough to cause an issue FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
24th Feb 2016 12:37am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Just a thought, could it be a dodgy receiver / transmitter for the transceiver chip in the key?
24th Feb 2016 3:41am |
