Home > Maintenance & Mods (L322) > Windscreeen vibration
ian
United Kingdom 2002 Range Rover Vogue Td6 Rimini Red
I have found, when going over 65, there is an odd vibration coming through the windscreen, which you can feel with your hand. it seems to be coming from either the passenger side top of the screen, or sometimes down near the wipers. trouble is it is not always there, even at the same speed. i have checked the trim pieces on either side of the screen and they are fine, so my next considerations are the wiper blades or loose trim on the bonnet. Has any one else had this irritating noise?
Post #374413 26th Feb 2016 10:05pm
Balki
Australia
vibration
I had the same problem and i ended up replacing the plastic valance panel below the screen, it comes with adhesive to the bottom of the glass, i ordered it genuine and only cost $200 aus
Post #374425 26th Feb 2016 10:26pm
kyle h.
United States 2006 Range Rover Westminster 4.2 SC V8 Java Black
A bead of silicon does the trick as well. I removed mine, painted in satin black (still looks a bit rough as the plastic degrades in the sun) and reinstalled. Afterwards ran a line of silicon on the rubber lip, used some heavy objects to hold it down in the areas it had warped.
see pictures on this thread showing the problem and heavy things to correct the warping.
http://www.landroversonly.com/forums/f40/h...ere-57072/
Post #374466 27th Feb 2016 5:06am
mike whiskey
United Kingdom 2002 Range Rover Vogue Td6 Alveston Red
I had the same problem. My solution was to get some black exterior grade sealant and run this under the black plastic panel at the bottom of the screen, then bed the panel down into the sealant against the screen. No more problem vibration.
MW Car history includes: LR Series 3, RR Classic x 4, LR 101, Discovery 1 and 2 and now FFRR.
Yes I'm a masochist....
Post #374586 27th Feb 2016 9:32pm
