Home > Wheels & Tyres > Range Rover sport 20inch wheels on a l322 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34915 |
yes they will with the newer 23mm shank nuts but the tyre size is wrong.. ... - .- -.
1st Mar 2016 7:02pm |
Coconut Member Since: 12 Feb 2016 Location: Watford Posts: 36 |
Could you advise as to the correct tyre size.
1st Mar 2016 7:06pm |
because of the 9.5j wide sport rim you need 275 45 20 size tyres... ... - .- -.
1st Mar 2016 7:10pm |
Thank you |
1st Mar 2016 7:25pm |
jonnyboy54321 Member Since: 29 Jan 2016 Location: surrey Posts: 380 |
I'm sure the wheels I have for sale are off a sport but are 8.5J ? Must check. 2007 Vogue TDV8 with 255/55/20's fitted |
1st Mar 2016 10:11pm |
^ they are 8.5j but they are from the new L494 sport and not the older sports.. ... - .- -.
1st Mar 2016 10:14pm |
Thanks Stan 2007 Vogue TDV8 with 255/55/20's fitted |
1st Mar 2016 10:28pm |
marsie Member Since: 30 Apr 2010 Location: sheffield Posts: 911 |
Fitted my old L322 with sport wheels but had to change the tyres to 275/45/20s. The standard sport tyres (275 40s) were only rated at 106 and looked tiny on the L322. Have now got the same sport wheels on my disco
12th May 2016 10:16pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2180 |
hi guys i have stormers off a sport (20s) 275 40 19 - they look a little small but seem to drive fine are you saying they are dangerous with these tyres and i quickly need to change to 45s? i checked the weight between ff and sport and its only 100 kg - 25kg per wheel and i never run fully laden |
12th Jul 2016 9:21pm |
