Home > Maintenance & Mods (L322) > right rear mudflap |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 |
use something like tigerseal Regards
9th Mar 2016 12:30am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
They usually have a bolt through the top... |
9th Mar 2016 1:23am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
If you have to glue it back then a polyurethane flexible adhesive (PU flex) is the best thing to use, it is the suff that the manufacturers use to stick most of the car together with now a days.
9th Mar 2016 3:01pm |
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 324 |
Cam-Tech-Craig, Its got a bolt through the top, but its on the arch, this is just behind it on the body.
9th Mar 2016 11:41pm |
