Home > Technical (L322) > Are all oils the same? |
steadyaway Member Since: 28 Feb 2015 Location: West Yorkshire Posts: 184 |
My 06 TD6 ffrr has 134k on the clock. As I use it to pull the tin tent I intend to change the engine oil and filter annually regatdless of mileage. The handbook recommends 5w40 fully synthetic to ACEA A3 + B3. I can get Comma oil to this spec for £18 per 4.5l. Is there any reason I should chose a "branded" oil such as Castrol for example, or are they all equal if they meet the required spec? |
9th Mar 2016 8:12am |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
I use the same oil in my td6.(comma).
9th Mar 2016 8:18am |
Luvverly thanks for that. I'll get some then.👍 |
9th Mar 2016 8:20am |
9th Mar 2016 8:29am |
Cheers will do. |
9th Mar 2016 8:30am |
