Home > Technical (L322) > Vibration / resonance on acceleration |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 |
There are lots of things it could be, have you started with basics and go the wheel balance checked, could be as simple as a weight missing.
22nd Mar 2016 9:57pm |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 416 |
A rough running engine can cause vibrations. Driveline vibrations won't cause a rough engine.
22nd Mar 2016 11:09pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Easy way to eliminate the gearbox is put it in Sport mode... it wont lock up or slip the TCC.... if your still getting the vibes then it will be engine related Yesterday I couldn't spell Engineer... Today I are one!
23rd Mar 2016 12:42am |
Mac1971 Member Since: 17 Jan 2016 Location: Hartlepool Posts: 30 |
Miggit , do you mean just sport mode or manual ? |
23rd Apr 2016 8:46pm |
there are 3 modes on the L322 gearbox, normal, then by moving the gear leaver left you get sport mode ( revs higher and opens the TCC ) and then by pushing the lever either forward or backward in sport mode you enter in to full manual mode So select drive and knock it to the left, but don't move it forwards or backwards Yesterday I couldn't spell Engineer... Today I are one!
24th Apr 2016 12:31am |
