Home > Maintenance & Mods (L322) > With thanks |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
I take it you have never done a brake fluid change before? Basically you add the new fluid into the reservoir and pump/vacuum that through until you see the clean new fluid coming from the bleed nipples. Plenty of YouTube videos available. Previously..
22nd Mar 2016 8:32pm |
ian Member Since: 24 Jan 2016 Location: chelmsford Posts: 22 |
i have changed fluid on land rovers and early discos and all sorts of older cars, but not sure if the ABS module makes things more complicated |
22nd Mar 2016 8:59pm |
22nd Mar 2016 9:07pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2025 |
ive not done my rangie, but done many others. there are plenty of kits available. its best to do it with an assistant. first, with a poundshop type gravy baster, or better still a syringe, draw out the old fluid from the reservior. then, when virtually empty, refill with new fluid. open each caliper bleed valve, with a device fitted. either use the air compressor connection type and blow air through, to create a vacuum, and observe clear fluid running through tube to pot etc, for a few seconds. retighten, repeat on all four corners. best to do fronts first. use a ring spanner on nipples, with previous soak with penetrating fluid. or, you can use the oneway valve method, and have you assistant pump pedal, whilst you hold the valve open a tad, and again see clean fluid for a few pumps. repeat all four corners. if you use the old fashioned jar and rubber pipe and undo, shout 'down' ....retighten, and shout 'up' you will be lucky to get it to be any better. this is hard to do. you just need to have plenty of paper roll, fluid, and an hour, to have fresh fluid etc. after each caliper, or whilst waiting, your assistant can observe the fluid level. unlikely to be really low. finally refill and carfully test pedal pressure, before going onto the roadtest!
22nd Mar 2016 9:26pm |
When I replaced all my brake pipes (after the ABS module) I used a Gunsons Ezibleed (there are other makes!) this prevented any air getting into the ABS module. If you do this with a closed system, even better, just fire up the Ezibleed and work your way around the nipples (starting at FL first! - read the manual) until you have clean fluid everywhere. (See wiki)
22nd Mar 2016 9:30pm |
thanks for the advice, wonder if i could do the thermostat and sender at the same time as the intercooler houses |
22nd Mar 2016 9:57pm |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 775 |
Remember you have two thermostats, the EGR Stat is on the top of the engine and sticks open. Easy to take off and test, if you can blow through it its stuffed. 2007 TDV8 VSE
23rd Mar 2016 5:26am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
Ian, why are you looking at doing the brakes yourself sir?
23rd Mar 2016 10:35am |
Forgot to say, my steering rack used to make a horrible graunching noise when on left turn on a cold morning. I lived with it for a while then it went away for good. Been OK for years. Have expected MOT man to point finger at the rack but has never done so yet YMMV .
23rd Mar 2016 9:14pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7764 |
I agree with Craig - I'm technically competent enough to bleed brakes, but IMHO not something I want to be messing with - I would rather leave it to someone a little less rusty than me who knows how to deal with seized components etc.
23rd Mar 2016 9:28pm |
Markjohns1 Member Since: 17 Jan 2016 Location: Cheadle hulme Posts: 139 |
How much would you expect to pay for a new steering rack fitted?been told casing cracked on mine 2004 vogue.brought to my attention when inspected becouse hieght adjustment was working dispite motors making a noise.Can you not pick up seconf hand/used or are they likely to be jiggered |
23rd Mar 2016 10:02pm |
Decided to have the brakes bleed by my independent, cost of £100. they first quoted 188+vat but suddenly came down to £100.
23rd Mar 2016 10:04pm |
The rack is in 5 parts basically,
23rd Mar 2016 11:07pm |
thanks will get it back later then under i go!! |
24th Mar 2016 9:08am |
